I have the Gigabyte GA-MA790FXT-UD5P motherboard with Phenom II X4 955 cpu, and I'm trying to decide between the F3-10666CL8D-4GBHK [http://www.gskill.com/products.php?index=95] memory and the Ripjaw F3-10666CL8D-4GBRM [http://www.gskill.com/products.php?index=224] memory. Both are listed as compatible with the GA-MA790FXT-UD5P motherboard according to G.Skill, but only the HK, and not the Ripjaw, is listed in Gigabyte's Memory Support List. What is the difference between the two? I see that there is a difference in timing: the HK memory is 8-8-8-21 and the Ripjaw is 8-8-8-24-2N. Is one going to cause me more problems than the other as far as having to make changes in the BIOS? Thanks!
Gigabyte GA-MA790FXT-UD5P motherboard with F3-1066CL8D-4GBRM memory?
