CPU - I7-860 (2.8ghz)
Mobo - Gigabyte P55-UD6 (rev 1.0)
Mem - Trident F3 17066CL9D 4GBTDS x2sticks (8GB Dual Channel)
Trying to get above 1600mhz if possible
Anyway
the memory is rated to 2133 and the mobo supports above 1600 but any adjustment of the actual memory speed above 1600 results in constant restarting
Manuals never help in respect to what BIOS settings actually do and in general i'm pretty cluey with PC's, Hardware and Software, but speed/timing settings are not my forte.
I've tried straight bumping the Memory speed to 2133 with XMP turned on, which is the only way to do it, XMP turned off and the memory will only go to 1600
the system becomes unstable with the Auto settings of XMP1
Anyway
