I5 750 (stock Cooler)
Gskill DDR3 1600 F3-12800CL7D-4GBRH
MSI P55M-GD45 (latest BIOS)
I noticed after enabling XMP in the BIOS so the memory will run at 7-7-7-24 that the CPU frequency went from 133 to 160 I guess to get 1600 for the memory. I turned the Multiplier down to 17 to get 160X17=2.72ghz for the CPU. When it posted I noticed it said 160X17 2.72Ghz then a couple of lines down it said something like "OS SYSTEM 3.2Ghz".
I ran a few tests and found that with XMP enabled (CPU-Z) I was getting 3.8Ghz on a single core at 100% and 3.2Ghz when all 4 cores were at 100%. I would get up to 80C and the VCore would hit 1.314.
With XMP turned off in the BIOS, (133X20=2.66) CPU=Z says 133X21=2.79(four cores at 100% 63C and 1.232 Vcore) and 133X24=3.2(single core 100%)
Can I manually change settings in the BIOS so the CPU is not overclocked to 3.2ghz (80C) (160X20) and the memory timing will be 7-7-7-24? Will this make the Memory any faster or will it only speed things up if I also overclock the CPU?
