I'm looking at purchasing some DDR3 ripjaw series memory and had a couple of questions that I was wondering if you guys could clarify. The models that I'm looking at are F3-16000CL9D-4GBRH and F3-12800CL7D-4GBRH.
1.) How tall is this memory including the height of the heat spreader. The system that I'm building is very space limited and I want to make sure that it will clear the other components!
2.) Would you suggest getting the higher 2000mhz memory with the slower timing 9-9-9-27 timing or the slower 1600mhz memory with the faster 7-7-7-24 timing. I'm not sure which makes the biggest difference and it appears that price wise they're almost identical!
3.) Will there be any trouble running 4 2gb sims in a msi p55-gd80 motherboard. Will running all 4 of these modules in that close of proximity cause any cooling problems?
Thanks,
Andy
Thanks,
Andy
