Recommend for F3-16000CL9T-6GBTD & EX58-UD4P
  • #16
    Getting there, keep us posted
    • #17
      Looking good--been running for 7+ hours now & very stable--BOINC running 90% CPU while I've worked with the system all day--web-browser/text-editing/general use. Backed the BCLK down just a bit--System is now running at 3.66GHZ instead of 3.7GHZ & memory timing is as before--temps are not going past the high 60C range--I'm sure there is a bit more to be pulled out--I just stopped so I could have a stable unit for the coming week.....
      MIPS per CPU currently:
      2360 whetstone
      4762 dhrystone
      • #18
        just cursios what QPI/vtt voltage are you guys using 1.26? 1.3 for the x20uncore frequnecy multiplier for the 10xmemory multi
        • #19
          I've left the QPI/vtt on Auto--bumped the Cpu V to 1.3500--uncore is @ 20 & Mem is @ 10--The Gigabyte board will only do 1.640 or 1.660 for Mem V & 1.660 is in the red--so I have set 1.640..I went back to Auto for almost all of the Mem advanced settings except for tRFC=62...went to 9-9-9-21 & 3.70 is stable--So I gave some mem timing for more QPI & CPU ghz.....It's about all I can do with this early 920--I'm going to be getting a 940 or newer 950 soon so I can "really" run the memory at its speed & hit 4.0......
          • #20
            for QPI/VTT voltage, you may need to increase it to 1.5-1.6v for early i7 920
            and as we tested, you may only run DDR3 2000 with 143 blk, not 200
            G.S
