Hello there.
First of all, please excuse my english. I’m from Argentina.
I’m planning to upgrade the memory on my rig. I’m currently using 2 x 1Gb G.Skill F3-12800CL7-1GBHZ (running at 7-7-7-18 1.90v), on a ASUS P5E3 Deluxe Wifi-AP@n with a Intel Core2Quad Q9650. I would like to stick with G.Skill, given the good results and performance I have so far.
I have two buying options:
- F3-12800CL7D-4GBRH (Ripjaws)
Or
- F3-12800CL8D-4GBTD (Trident)
I would like to know what would be the best choice between those two. I know that Ripjaws series are mainly targeted for P55 chipset, and Trident for X48 and P45 (closer to my M/B chipset). But if I can choose, I would go for the Ripjaws series, mainly because its lower latency.
Is F3-12800CL7D-4GBRH compatible with my motherboard?
And by the way, what settings in BIOS should I take in consideration for each pair to get a stable system? You know, voltages and stuff.
I plan to use them at their respective specs. What I mean is, I'm not willing to replace my current memory (working flawlessly), getting a new one that ends running below its own specs (i.e: 1333Mhz, or high latencies) or worst (BSOD, inestability).
Thanks for your time and patience, and looking forward for an answer.
Sincerelly yours, Gerardo from Argentina.
Or
