I have a 2x2GB pair of Ripjaws (F3-10666CL7D-4GBRH) in my new build:
I7 860 + Asus P7P55D Pro
I am experiencing various BSODs in the form of:
MEMORY_MANAGEMENT, IRQ_NOT_LESS_OR_EQUAL, BAD_POOL_CALLER, PFN_LIST_CORRUPT... when doing nothing but browsing, or playing a game, doesn't really matter.
I have run memtest86:
dual channel - fail
single channel - pass (both tested separately)
Screen Shots Below:
Bios Voltages:
Timings Level 1
CPUZ Memory Timings in Dual Channel Mode
Memtest with Both Sticks - Fail
Other image links (since you dont allow more than 4):
General Bios Settings:
http://www.siriusweblabs.com/Images/...s-settings.jpg
Skew Control
http://www.siriusweblabs.com/Images/...ew_control.JPG
Slew Rate
http://www.siriusweblabs.com/Images/.../slew_rate.JPG
Timings Level 2-3
http://www.siriusweblabs.com/Images/...ing-lev2-3.JPG
CPUZ Memory Timings in Single Channel (One stick)
http://www.siriusweblabs.com/Images/...pro_single.JPG
Memtest Single Stick - Pass (tried both sticks separately in slot a1 and slot b1)
http://www.siriusweblabs.com/Images/...lota1_pass.JPG
Ram Timing Label Differences, how am I to know:
CPUZ Current Memory Speed: 9-9-9-24-72-2T
CPUZ JEDEC #4: @666 9-9-9-24-33 1.5V
CPUZ XMP1334: @667 7-7-7-19-31 1.6V
Sticker (on ram): 7-7-7-18 1.5V
GSkill Website: 7-7-7-21-2N 1.5V
Not sure what timings to set, nor do I know how since the BIOS has different names and more settings than I know what to do with.
Regardless, is it really timings if the failure is only in dual channel and they pass in single one at a time?
Help is appreciated, seems like one stick works but as soon as they are combined, it becomes unstable. I need to get this PC working soon since I use it for work.
Thank you in advance.
dual channel - fail
Screen Shots Below:
Bios Voltages:
Timings Level 1
Skew Control
Slew Rate
Timings Level 2-3
