I have the ASUS ROG Crosshair V Formula-Z AM3+ AMD 990FX + SB950 and AMD FX-8350 Black Edition Vishera 8-Core 4.0GHz. I'm considering upgrading the CPU to something faster.
I mostly run applications and really want to tweak up the speed wherever I can (I am impatient). My idea is to get 2400Mhz memory and either OC the motherboard to handle the 2400 or use the 2400 with tighter timings.
I have not really done much overclocking before. What do you recommend I do? Which will be faster for running applications? Which G.Skill memory should I buy for this combo? What processor should I get to match up to the memory? I was pretty much thinking I'd get the AMD FX-9590 Vishera 8-Core 4.7 GHz Socket AM3+.
Money is not a factor. If there's any gain, I want it.
Also, I currently run 32 GB of ram. I have read that using more slots is slower than 2 slots. There's also the load on the MB/CPU to consider I suppose. Would I be better off tweaking for speed with only 2 slots of ram / 16 GB or will I get the same performance with 4 slots / 32 GB?
Any advice is appreciated. And I'll also need to find the posts regarding overclocking the MB for the memory.
