I stumbled into the fact that my G3258 cpu did strange things when I had the Ripjaws Z 2400-10 memory installed. Once I replaced the memory with 1.35V 1600-9 memory all was well.
Now, I'm wondering if the 1.65V for the Ripjaws Memory is affecting my ability to OC a 4790K on an ASRock Extreme6 MB. The 4790K refuses to run sable over 4.6GHz. So... instead of buying more 1.35V 1600-9 memory to test my theory is it possible to plug settings in the BIOS that will slowdown the Ripjaws Z to 1600-9 with a lower voltage.
I've tried Auto and that slows the memory to 1600 but leaves the voltage at 1.65V. Can someone give me the absolute minimum settings I need to get this stuff to run at 1600 at 1.35 or 1.5V. Thanks.
