Hi, I ordered an Asus Crosshair V Formula-z and was wondering if the Trident-x 2400 kit is a good choice for for my setup. My CPU is an FX-8320E
If my IMC does not like running RAM at 2400, would it be as simple as just lowering the speed and timings to get them in shape?
Also I was was wondering how tall these sticks are after removing the fins, are they 39mm with the fins removed? I have a very large air cooler (Cryorig R1 Ultimate) and 40mm is about as tall as I can go.
Thanks a lot.
Edit:
I have confirmed that they are 39mm with he fins removed. And according to another thread I should be able to under-clock them if I should run in to any issues while running them at 2400.
If there is any other info I should be aware of, please let me know.
Thanks again.
Thanks a lot.
Edit:
Thanks again.
