Hello again,
it's been a while since I last wrote in this Forum, but now I am back with a new build and a new problem. ;-)
I've recently bought a Gigabyte GA-970A-UD3P Mainboard and an AMD FX-8350 CPU together with the above mentioned RAM modules.
Now there is an issue with this board not being able to run DDR3-1866 in all 4 DIMM Slots, but the manufacturer states this on his website, so there is nothing to do about that.
However, since I cannot run my RAM at 933MHz, like I was hoping to, I thought I might be able to run the RAM at sharper timings and 800MHz and have been trying to do so very successfully. My current timings are 8-9-9-24 CL1.
Now my question is, if there are timings like the XMP for this RAM @800MHz that were tested by G.Skill, so that I do not have to manually try to find out the limits of the RAM and to not void the warranty on the RAM.
I've already used AIDA64 to find out about the timings in XMP, but there are just standard timings given for 800MHz.
Thanks in advance
nine_seven
Thanks in advance
nine_seven
