Both are 16GB DDR3-1600 2x8's
They're the same Ripjaw X's but ones blue and ones red...
But the blue is listed as Cas 9
http://www.gskill.com/en/product/f3-1600c9d-16gxm
http://www.newegg.com/Product/Produc...82E16820231568
While the Red at Cas 10...
http://www.gskill.com/en/product/f3-12800cl10d-16gbxl
http://www.newegg.com/Product/Produc...82E16820231489
So I am wondering why the blue specifically has a lower Cas as they're supposedly identical sticks in just a different color heat spreader?? Or is there some other difference, different chips?
