Hey all, and Tradesman.
I have a somewhat trivial question, that is almost a matter of opinion.
I want to upgrade from my F3-14900CL9D-8GBXL modules. These are 2 x 4 dual channel DIMMS at 1866. I Need 16 GB now a days in some intense games and future proof. So, rather than risk getting the sticks above again and risking compatibility, What is the best for board listed below? Keep in mind, I'm thinking of moving to 2133 MHz or higher, if the cas can be kept to 10 or even 9, otherwise its kind of a wash in speed. Is it best to use 2 sticks or will a quad channel kit of 4 work well? If so, I would look into a more "even" spread of quad because I do plan in the next year or so to get a new motherboard and cpu that supports quad channel for a serious gain. However, if id lose performance on this dual channel board by using 4 sticks, let me know. What is the best case ... and modules for this board you can recommend? Here are 2 I really like
G.SKILL Ripjaws Z Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL8Q-16GBZM
above I love the 8 CAS and quad ready however it doesn't state it works with the Z77, just X79 and 2011 chipset.
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-2133C9D-16GXH
This is faster with a great CAS and is 2 DIMMS
My motherboard is ASrock Z77 Extreme 4
currently have a core i5 ivy OC at times to 4.5 stable
Please Advise, Thank you
