My PC has a Gigabyte Mainboard GA-P55A-UD4, bought January 2010 together with a pair GSkill F3-12800CL9D-4GBNQ.
It was not possible, to use the XMP-Profile, probably because the RAM was not programmed with the usable data. Set SPD to auto, they run wit 1333 MHz and CL 9-9-9-24
Now a bought another PAir of the same RAM to increase the capacity.
I tested this pair alone in dual-channel mode and to my surprise the xmp-profile is now available and works with this pair.
I didn't yet try the combination of the two pairs, because i'm not sur, how to proceed.
Which setting can and should i use for the combination? Tty the xmp-profile of the new pair or using lower settings?
Would by fine, if you could help me.
