Need help choosing RAM
  • Need help choosing RAM
    I need help choosing RAM. I've used the RAM configurator for my motherboard and have narrowed it down to three choices. I want to know which 8GB kit is the fastest, overall.
    1) F3-14900CL8D-8GBXM - 1866MHz - CL8-9-9-24
    2) F3-17000CL9D-8GBXM - 2133MHz - CL9-11-10-28
    3) F3-2400C11D-8GXM - 2400MHz - CL11-13-13-31
    Obviously more MHz = faster but I'm unsure of the impact CAS latency has. Is a 2400MHz CL11 really faster than a 1866MHz CL8?
    If you just want to get DDR3-2400 with no manual tweaking or overclocking get #3. I guess #3 is probably the cheapest option as well. However if you wouldn't mind overclocking you memory, #2 should also do DDR3-2400 with even better timings than #3.
    Yes it is. Even DDR3-2000 CL7 can barely / can't match DDR3-2400 CL11/CL10 in terms of bandwidth. Also the F3-2400C11D-8GXM should be a double sided kit, so there is no rank interleaving performance penalty (that all the high speed kits using single sided Hynix MFR suffer from).
      What if I wanted to go 16GB? 2x 8GB or 4x 4GB? Obviously higher density sticks will have higher latency. But is there any other performance/stability advantage between the two setups? I've read somewhere that it's better to stick with 2x 8GB but can't remember the reason why.
        Although the newer Intel platforms, because of their T-topology used for the memory slots, do a lot better with four modules than their predecessors, i'd still go with 2x8GB if you're not overclocking.
          I'm not overclocking. And I just discovered my CPU cooler fan is blocking my first DIMM slot. So 2x sticks only. I don't know how I missed that..
          Anyways, I've decided 2x 8GB is the way to go for future proofing. I've narrowed my choice down to this:
          F3-2133C9D-16GXH - 2133MHz - CL9-11-11-31 @ 1.60v
          Do you know if this is a double sided kit?
          And thank you for all your expertise.
            As of now, all 8gb modules (2x8, 4x8 kits) are double sided.
