I have G.Skill PC19200 16GTX. It's a 16GB dual channel kit and I'm using it with 3770K and Gigabyte Z77X-UD3H. This memory is designed to run on Ivy Bridge and my motherboard is qualified for it.
My problem is when I enabled XMP profile (2400 MHz @ 10-12-12-31 2T) my wi fi speed drop from 400 kBps to about 150 kBps. Sometimes it goes to 400 kBps but then drops to 90 kBps but when I run the memory below 2400 MHz (starting from 2200 MHz) the wifi speed back to normal.
Are there ways to fix my problem?
Thank you.
i7 3770K
Gigabyte Z77X-UD3H rev 1.1
OCZ Vector 256GB
TP-LINK TL-WN781ND V2
Corsair AX860i Platinum
Windows 8 Professional with WMC x64
Thank you.
i7 3770K
OCZ Vector 256GB
