Model F3-14900CL10Q-32GBZL and GIGABYTE GA-990FXA-UD3
  • Model F3-14900CL10Q-32GBZL and GIGABYTE GA-990FXA-UD3
    It's been years since I've built my own computer so I'm kind of lost. I'm just trying to get the ram up to 1600. I know it won't run at 1866. What setting do I need in order to achieve 1600?
    AMD FX-8350
    Might take a look here, and see how it goes, the member includes a lot more info than I would initially provide. Slightly different mobo, but same GB base
    http://www.gskill.us/forum/showthread.php?t=12360
      Thank you. I'll give it a try.
        Let me know how it goes!
          Didn't work for me.
            What did it do, not do? Did it load and then Blue screen, not start at all or what?
              I didn't see dram eocp or DCT setting in my bios. It won't boot then the board resets to the default bios settings.
                I'll pull down a manual and take a look, back later this PM
                  Enable DOCP/EOCP, raise CPU-NB Voltage +0.1V and see how that works.
                    I have yet to find any DOCP/EOCP settings.
                      I've tried using xmp also.
                        Might want to try 1600, 10-11-10-31, 2N, DRAM 1.55, CPU/NB 1.3, and tRFC about 270
                          I see two tRFC settings. One is tRFC0 and the other is tRFC1
                            Change both
                              No luck. Most likely I'm missing something. I can though get it up to 1866 on two sticks.
