Hi there,
Just wondering if anyone can advise the best settings for
F3-1866C10D-16GAB (2x8GB)
Asus M5A97-EVO MB
Phenom II 925 x4
Planing to use Windows 7 Pro 64bit
and hoping to be able to update a current OS install.
Current MB is a Asus M2N-E (which is NVidia chipset)
2 questions:
A). Will the above work together, what settings should I use for the G-Skill memory?
Not so relevant to this forum but here goes anyway...
B). Will it boot up enough to update chipset drivers? (I'm thinking nope...)
Any other way to get the drivers installed/ready before I hookup new motherboard?
...Can I extract the new chipset drivers from the Exe somehow?
P.S. I'm going to ask 2nd question on an Asus/Tech forum too!
PPS: I see part of my answer in the sticky above "AMD CPU + G.Skill DDR3-1866"![Smile](https://www.gskill.us/forum/core/images/smilies/smile.png)
Thanks,
Josh
Asus M5A97-EVO MB
Phenom II 925 x4
2 questions:
Thanks,
Josh
