Memory compatible with ASUS P9X79 Pro MB
  • Memory compatible with ASUS P9X79 Pro MB
    Will G.SKILL Sniper Gaming Series 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9T-12GBSR2 work with ASUS P9X79 Pro ATX MB with Intel Core i7-3930K Sandy Bridge-E 3.2GHz CPU
    Won't get quad channel performance as it's a 3 stick set and may have to run higher DRAM voltage, not sure if they have the BIOS tuned for low voltage sticks on that mobo
