Hey all. I'm new to G.Skill memory and having some problems.
I have
G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBXL
and am running it with
Intel Celeron G1610 Ivy Bridge 2.6GHz LGA 1155 55W Dual-Core Desktop Processor BX80637G1610
on a
GIGABYTE GA-B75M-D3H LGA 1155 Intel B75 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Oddly, the memory is running at 1330 MHz and I have no ability to change that in the BIOS. There are no options to use the XMP profiles. It's very odd, the memory should run at 1600 MHz as the CPU is an Ivy Bridge 22 nm processor, and so I should be able to enable XMP and have everything run.
Frankly I don't know if it's a problem with the memory or the motherboard. I opened a ticket with Gigabyte earlier today at the same time I requested to join this forum.
Any thoughts?
I have
on a
Any thoughts?
