Hey guys this is probable going to be a pretty nubby question but whateva,
I bought some F3-10666CL9D for my Gigabyte GA-EP43T-USB3, didn't even think there should be a problem until i noticed on the memory packaging "Compatible with Intel LGA1155/LGA1156 systems."
I tried installing anyway but I get numerous short beeps followed by computer reset, and this happens in a never ending loop.
I take it these wont work with my Intel Socket 775 P43 mb will they? Can you recommend any 8GB kits and above that would work with my motherboard?
Thanks all
Thanks all
