Not new to builds, but never did much with overclocking/tweaking. Just want my ram to run at the rated speed, and I hear that I need to set it manually. I have a Gigabyte GA-990FXA-UD3, AMD FX-8150 and Gskill Ares 16GB (2x8) DDR3 1866 (PC14900). Ram is of course running at 1333 in auto. Thanks for any help.
Ares 1866 and Gigabyte 990FXA
system voltage
I checked the bios and it's the latest release. Found EOCP, not DOCP, but figured that was it since there was an option to select 1866, however when I did, it then warned that the system voltage wasn't correct. Not sure what to do with that so... still stuck at 1333 for now :-)
