Originally posted by GSKILL TECH
View Post
What is XMP?
It may seem like JohnJSal is asking simplistic questions, but the answers are helping me a lot but not completely. I'm planning my first build and I'm terrified of trying to understand what will happen with different RAMs -- the compatibility issues and the confusing terminology are scary. For an Asus P8Z77-V Pro mobo using a i7-3770k cpu I was thinking of options:
[ RipjawsX] F3-17000CL9Q-16GBXM (4GB x 4) tested speed DDR3-2133 PC3 17000 @1.65v; SPD 1600mhz @1.5v
[ RipjawsX] F3-2133C9D-16GXH (8GB x 2); Tested DDR3-2133 PC3 17000 16GB CL 9-11-11-2N 1.6V;SPD Speed 1333 mhz @1.5v
[ RipjawsZ] F3-12800CL9Q-16GBZL (4Gx4); DDR3-1600 PC3 12800 16GB(4GB x 4) CL 9-9-9-24-2N 1.5V; SPD speed 1600mhz @ 1.5v
Assuming I turn on XMP:
The 1st should give 2133 mhz or is it only 1600mhz; how is the voltage changed and what is it's impact?
The 2nd is the same 2133 mhz but SPD is 1333 mhz. which do i get?
The last bet gives me 1600mhz only.
Incidentally, G.Skill's Ram Configurator presents (for the ASUS P8Z77-v PRO mobo) a compatibility list of 120 Ram selections in random order - there is NO logic to the sequence of items presented. After trying to find all the 16 GB Dimm's and checking individual details in another window, I am exhausted and seriously considering abandoning G.Skill.
Your people must find a way to allow customers presented with this big a selection, to be able to filter the list on size, speed, SPD, etc, and to sort it by several parameters and provide all the info upfront.
Fred
There is no wa
The SPD speed you refer to, is nothing more than the basic default boot parameters....Most every mobo out there defaults to either 1333 or 1600 for booting purposes whenever it detects new DRAM has been installed..so it's really not worth worrying about, or give thought to. With your mobo/CPU combo for 2133 2x8GB I like your choice, the Ripjaws X F3-2133C9D-16GXH, if you decide to go 4x4GB 16GB 2133, then I'd suggest the 2133 F3-17000CL9Q-16GBSR Snipers first (a little higher OC headroom), and your choice the Ripjaws X F3-17000CL9Q-16GBXM, as about equal (I've just had better luck w/ the Snipers in OCing, in fact have a set of these running at 2400 w/ a P67/2500K combo. At 1600 basically any of the sets will be fine, and I personally have no real overall pref (except again with the Snipers for Over and Under clocking
Well, the upgrade went great, no problems! However, I noticed this line in the XMP sticky:
"Before enable XMP, please update with latest version of Motherboard BIOS and clear the CMOS."
Is this necessary? I'd rather not mess with upgrading the BIOS or getting back into my case anymore, just to do this.
Thanks.
Edit: My board is a Gigabte GA-Z77X-UD5H
