I sent an email to GSkill customer support asking if a certain type of their RAM (F3-12800CL9D-8GBXL) was compatible with the MSI Z77 MPOWER motherboard, and this was the response:
I know there are guides in the forum that tell you HOW to do this, but can someone explain to me what this even means? I'm not really one to mess with the BIOS or do any of these extra tricks, so is this something I would need to do at all if I don't plan to overclock? Will the RAM not work properly at all if I don't do this?
Thanks,
John
Dear Customer
Yes, no problem at all, just make sure to configure settings in BIOS or enable XMP Profile.
Thanks,
John
