system spec: i5 3570k - 4x4 F3-12800CL9Q-16GBSR1 - asus sabertooth z77
this is my first build and i'm not familiar with a lot of terms and do not know what to set them as.
I want to overclock my cpu and ram, what should i set the ai tuner to? X.M.P or manual?
at auto memory modules work at 1600mhz 11-11-11-27.
When i switch to X.M.P memory modules work at 1600mhz 9-9-9-24 1.35v as advertised, do i keep it at this sitting? or change to manual? (i read that manual is better than X.M.P)
can i overclock ram to 1800-1866mhz or more with same advertised timing and volt? or should i change them?
sorry for asking alot of questions, i'm new to this stuff and thank you in advance.
