Hello, guys!
It's been two months since I got this stuff:
- Asus P8Z77-V LK
- gskill F3-12800CL9Q-16GBRL (ddr3 4x4gb 1600mhz)
- Intel i7-3770
The other components I got from my old PC:
- gtx570
- corsair 650w
- some ordinary HDs...
Since the very first time I put everything togheter, I got boot loop because of the memory. After messing A LOT with the modules, the only pattern I've found out is that when all the 4 slots are full, the board does not boot.
If I change the memory settings on bios bypassing the check with MemOK asus button, I can get it working with 1333mhz and 1.6v but it fails on Memtest or Windows boot.. XMP does not work.
Mem sticks work with any combination (single, in 2, in 3, on any slot) but not when 4. This is very strange...
Anyway, I RMA the motherboard. They send me back after testing with another RAM sticks and saying to me that the board was everything ok...
Then I got the chance to check those mems on a Gigabyte board with an i7 2600k, and I got the same problem! Mem works on any combination but not 4... I RMA the memories and they send me back after 2 weeks saying that they tried the kit on several boards and it worked everything fine.
Now I don't know what to do! Is that possible that I'm the most bad luck guy in the world that got two bad Memory Control CPUs during both tests? oO
- Asus P8Z77-V LK
- Intel i7-3770
- gtx570
- corsair 650w
