Configuring my memory
  • Configuring my memory
    I just built a new system and the motherboard put the ram speed at 1333. Using the motherboard, it just had a drop down menu to set it to 1600, which I did. I was curious if that is fine or if I should set it manually. If manually, what would be the proper settings to set it at?
    David
    AMD FX-4100
    ASUS M5A97
    G.Skill 4GB F3-12800CL9D-4GBRL
    Can always go into BIOS and see what the timings are set to, should be 9-9-9-24, CR (Command Rate) at 2T or 2N and DRAM voltage at 1.5
      Well, there are two pages of timings on this. The first 4 do say 9 9 9 24, however when I drop down to the end of the 2nd page the command rate is set to 1T.
        Try that at 2T, should be more stable, though if stable 1T provides a slight performance boost
