Dear all,
I have build a new system (my third one) with the following components:
ASUS P8Z77WS
I3770K
G-SKILL F3-17000CL9Q-16GBZH (4 modules)
Corsair 850W PSU
Radeon 7850 Graphic
After the first boot (no problems) it went wrong.
The second boot from power off hangs the mobo with de led Diag Dram burning.
If you push the button MEM OK the system reboots a few times and if you are lucky you can go in the BIOS.
The BIOS shows DRAM freq 800Mhz. When i select XMP profile 2 (2133 what the memory must be) the system boots when it is a warm boot (no power of). If you do some tests with Prime95 no errors.
If you do a power off and than starts again the system hangs with the Diag Dram led burning and code 77 on the Qcode from ASUS.
Push the button Mem OK and there is a chance to get in the BIOS. The Dram freq stands again on 800 Mhz or less.
I have read on this forum simular problems.
Can you help me what goes wrong?
LeoV
Netherlands
ASUS P8Z77WS
I3770K
Corsair 850W PSU
Radeon 7850 Graphic
LeoV
Netherlands
