Hello guys!
I've been in some serious discussions with a few buddies of mine, i'm about to get myself a new computer and therefore im going to be running with the following motherboard:
http://www.asus.com/Motherboards/Int...specifications
Now as you can read the motherboard supports: 4 x DIMM, Max. 32GB, DDR3 2400(O.C.)/2133(O.C.)/1866/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Quad Channel Memory Architecture
Which to me looks like you can maximum run a quad kit of 1866mhz OC'd to 2400mhz, is this correct?
The CPU im getting is the I7-3930k and so i've been told that i could even run PC3-19200 ram dimms and i quickly got my eyes on the:
http://www.memoryc.com/computermemor...hzquadkit.html
which looks rather f***ing sick if you asked me, now the final question is.. Will these ram dimms be able to run properly with this motherboard + CPU?
Please leave an answer
