Hi guys...
I am trying to test the top max overclock i can get with my kit of 40GB.
I'm with this settings now
FSB - 475Mhz
CPU Multi - 8.5
CPU Freq - 4037Mhz
Mem - DDR2-1141
FSB Strap to NB - 333Mhz
Dram timings
CL - 5
RAS# to CAS# Delay - 6 ->7 -> 8
RAS# PRE Time - 6 ->7 -> 8
RAS# ACT Time - 17 ->19 -> 21
RAS# to RAS# Delay - 6 -> 7 -> 8
REF Cycle Time - 70
WRITE Recovery Time - 8
Command Rate - 2N
All the rest is auto
CPU PLL Voltage - 1.52v
FSB termination Voltage - 1.22v
DRAM Voltage - 2.10v
NB Voltage - 1.45v
SB voltage - Auto
Clock Over-Charging Voltage - Auto
NB GTL Voltage Reference - 0.61x
Even with this settings, memtest86+ v4.20 is reporting errors in test #5.
Can anyone give a hand on getting this stable???
I'm at latest BIOS in my board...
Edit;
Changed values to the red ones...
I've been increasing values in red but i'm getting errors at memtest86+...
FSB - 475Mhz
CPU Multi - 8.5
CPU Freq - 4037Mhz
Mem - DDR2-1141
Dram timings
CL - 5
REF Cycle Time - 70
Command Rate - 2N
NB Voltage - 1.45v
SB voltage - Auto
Edit;
