F2-8000cl5-2GBPQ & EVGA 780i
  • F2-8000cl5-2GBPQ & EVGA 780i
    Model of the motherboard: EVGA 780i (132-CK-NF78)
    Model of the memory: 2x 2GB PC2-6400 (F2-8000CL5-2GBPQ)
    Model of the CPU: Intel Core 2 Quad Q6600 (Kendsfield @ 2.40GHz)
    What is the problem? trying to determine safe overclock timing etc for the memory
    Thanks!
    P.S I used to be able to find a document on this site for this model but was unable to find it.
    Edit: Misread, provided incorrect info.
      thanks
      Thank you for the response, what should the Frequency and timings be set to?
        DRAM base timings of 5-5-5-15, CR at 2T, DRAM voltage at 2.0 and speed (freq) at 1000
