model of the motherboard: Gigabyte EP43-UD3L
model of the memory: F2-8500CL5D-4GBPQ
model of the CPU: Intel E7400
When I try to run the memory at 1066 mhz with 5-6-6-18 timings at 2.0 volts, the computer bluescreens after loading up vista. I memtested each stick individually at 1066 and each received no errors, but together at 1066 it failed and they blue-screen. After changing to 800 mhz they pass memtest and do not blue screen.
Is there a way I can get it to work at 1066? Have you tested it with my motherboard before?
Thanks a lot!
Thanks a lot!
