I've read all the relevant posts, here are my specs:
- G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-2GBPK
- JetWay JXBLUE-N78V AM2+/AM2 NVIDIA GeForce 8100 HDMI Micro ATX AMD Motherboard - Retail
- AMD Kuda 7750 Dual Core AM2+ CPU
The mobo supports 1066 with an AM2+ CPU. It's got an Award BIOS with an "Overclock" setting, which is on "Auto", which picks 800mhz. When I set it to 1066 and reboot, it won't post and I had to reset CMOS. There's also a separate screen that allows timing adjustments, which are NOT at the 5-5-5-15 that this memory advertises. It's set to Auto-9-9-15, with VDIMM voltage at 1.84V.
I've set it to 5-5-5-15, no post. Set it to 5-5-5-15 with 2.1 voltage, no post. Set it to 5-5-5-15 with 2.1 voltage and 1066 "overclock" speed on the other screen, no post. Growing weary of pulling out the power and using jumpers to reset the CMOS...
HEEEEEEEELP
HEEEEEEEELP
![Smile](https://www.gskill.us/forum/core/images/smilies/smile.png)
