I bought a 4GB GSkill Memeory kit (F2-8500CL6D-4GBNQ) & a Gigabyte GA-EP43-DS3LR motherboard from Newegg.com
I can run the memory fine & it is stable at 800Mhz 2.0v. But I cannot get my system stable if I set it to 1066Mhz. I have tried increasing the voltage to 2.1v, I also tried increasing the MCH by .5v as suggested in other forum posts. I have also tried manually setting the memory to 6-6-6-18 @2.0v with no joy.
I just cannot seem to get it to work at 1066 no matter what I try. I can run the sticks one at a time or I can run both in single channel mode.
I have a Gigabyte GA-EP43-DS3LR motherboard with an Intel Q9550 CPU. I am running at stock speeds & do not overclock.
