I recently bought http://www.newegg.com/Product/Produc...-122-_-Product
to upgrade the ram on my Hp Pavilion Media Center m8400f, I have four memory slots the first two are 512MB and the second two are 1GB, I have tried to install them twice now but when I try to turn the computer back on it doesn't boot, it makes noise but nothing happens on the screen, I replaced the new ram with the old 512MB ones and it starts up fine I hope that you can help me find a solution.
Thank you for any help.
