Hi, I bought 2GB RAM paths each, Model F2-6400CL4D-4GBPK and since I have theminstalled, I experience problems that the computer does not respond at times like to share a video with another computer within a home network , to pass data by FTP or using the software to watch TV Veetle instead to put my old RAM, all problems disappear.
My data on the motherboard are:
Computer:
Computer Type ACPI x64-based PC
S.O. Windows 7 Ultimate
Service Pack -
Internet Explorer 8.0.7600.16385 (IE 8.0 - Windows 7)
DirectX 11.0
Motherboard:
CPU Type QuadCore Intel Core 2 Quad Q6600, 2400 MHz (9 x 267)
Motherboard Name Asus P5K SE (2 PCI, 3 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
Motherboard chipset Intel Bearlake P35
System Memory 4096 MB (DDR2-800 DDR2 SDRAM)
DIMM2: G Skill F2-6400CL4-2GBPK 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz)
DIMM4: G Skill F2-6400CL4-2GBPK 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz)
BIOS Type AMI (06/25/09)
Monitor:
Video card ATI Radeon HD 3870 (512 MB)
I have configured from the BIOS the voltage is 2.10V and 4-4-4-12 latency memtest86only and I have done has been correct.
I hope you can give me a solution that took months and desperately tried everything, but I did not answer.
EDIT: I have passed the Memtest86 + and I'm not any error. Well if used separately, operate correctly
Computer:
Service Pack -
DirectX 11.0
Motherboard:
Monitor:
