I'm hoping that a tech here (or someone smarter than me) will help me figure out if I have a faulty memory stick or dodgy motherboard.
I have a system with the following components:
GA-MA770-DS3 (rev. 2.0) (latest BIOS default settings)
F2-6400CL4D (4*1GB)
AMD Phenom 9950 Quad Core
System has been running perfectly for almost a year until recently when I started getting stability issues and random (but numerous) bad sectors on my HDD's. Thinking my HDD's might be shot I low level formatted them and they passed all tests, meaning data must be being corrupted before the disks.
I ran memtest86+ which found about 110 errors in tests #5 and #7 and following are the steps I took to troubleshoot the memory and motherboard.
1. Tested each memory module separately in slot 1, all passed with no errors.
2. Tested each memory module separately in every slot, all passed with no errors.
3. Reinserted all memory, tested, 1st pass 16 errors in test #7 and 2nd pass even more errors in test #7 and about 90 in test #5.
4. Noticing all errors happened around the 1250-1252MB address I removed the memory from slots 1 & 2, tested memory in slots 3 & 4, all passed with no errors.
5. Took the memory from slots 3 & 4 put them into slots 1 & 2, tested, all passed with no errors. Removed and marked as 'correctly working'.
6. Installed remaining memory into slots 1 & 2, tested, 1st pass 16 errors in test #7 and 2nd pass even more errors in test #7 and about 90 in test #5.
7. Removed memory from slots 1 & 2, installed them into slots 3 & 4 (to rule out faulty dimm slots), tested, got exact same errors as in step 6.
8. Removed memory from slot 3, replaced with marked 'correctly working' memory stick, tested, all passed with no errors.
9. Removed memory from slot 4 and marked as 'correctly working' (leaving marked 'correctly working' memory in slot 3).
10. Installed memory removed from slot 3 in step 8 into slot 4, tested, got exact same errors as in step 6.
11. Removed memory from slot 4 and marked as 'faulty'.
All the testing points to one of my memory sticks being faulty (final stick in slot 4) but it only seems to be faulty when paired with another memory stick (any memory stick) and passes all tests when tested separately.
So is this memory stick faulty or do I have motherboard problems?
I would really like to pin point the issue before replacing hardware that may not be the problem.
Any suggestions, help or recommendations that you guys are able to give would be very much appreciated.
F2-6400CL4D (4*1GB)
