hello i just bought f2-9600cl5d-4gbpi on a asus p5q pro turbo mb my processor is a core 2 duo e7400 can you plz give me the correct bios settings in detail because i am kind of a noob ,thank you
bios help
Ai Overclock Tuner - Manual
CPU Ratio Setting - 8
FSB Frequency - 375
DRAM Frequency - DDR2-1200
DRAM Timing Control - Manual
CAS# Latency - 5
DRAM RAS# to CAS# Delay - 5
DRAM RAS# Precharge - 5
DRAM RAS# Activate to Precharge - 15
DRAM Voltage - 2.10V
NB Voltage - 1.15V
Let me know how this works.
Without knowing your previous settings, it's prob a slight OC to the CPU along w/ correct timings for the RAM. Your P5Q mobo defaults to a 1333 FSB and it now is running at at 1500 (which is no problem - it's rated up to 1600 and I've seen them running even faster)
