Hello
this memory keeps freezing my system for a few seconds then the computer resumes and start working normally.
took me a long time to pinpoint the problem as first i thought it was the processor, then the mainboard! now that i have replaced both the problem persists.
the bios of this motherboard wont let me set timings manually
http://i30.tinypic.com/24696rs.png
I can only set ddr overvoltage and memory multiplier i tried several different settings and when i add DDR overvoltage +0,2 which brings it to 2,1v which is the recomended settings the system still freezes, but it occurs less often.
If i leave it at auto, the bios assigns 1,9v to the ram and it freezes a bit more.
any suggestion for bios settings that could make this memory work fine? i already had run memtest in dos and both memory modules didnt have any errors.
