DDR2 Ram - G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-4GBPI-B
Video - SAPPHIRE 100265L Radeon HD 4830 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
MoBo - ECS BLACK SERIES A780GM-A AM2+/AM2 AMD 780G HDMI ATX AMD Motherboard
ecs mobo bios is up to date
CPU - AMD Phenom II X4 920 2.8GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM2+ 125W Quad-Core Processor HDX920XCGIBOX
upgraded to quad core from dualcore
Previous CPU - AMD Athlon 64 X2 7750 Kuma 2.7GHz 2 x 512KB L2 Cache 2MB L3 Cache Socket AM2+ 95W Dual-Core black edition Processor AD775ZWCGHBOX
I have gotten about 140 BSODs over past 18 hours after upgrading CPU
I had decided to upgrade my CPU from a dual to a quad core. Right off it started giving me BOSDs anything from bad pool, irql problems, registry problems, ect. I hvae probably gotten about every BSOD code there is by now.
Through a bit of trial and error I have discovered it is my RAM that was giving me the problem.
Had zero problems with the dual core CPU and had run everything in bios at default.
Now with the CPU upgrade I have had to remove 1 of the DDR2 Sticks and manually set the RAM at 4-4-4-12-12 have it limited at 400mhz setting also.
I have tested swapping out the sticks into different RAM slots (2red, 2 yellow) 1-2, 1-3, 1-4, 2-3, 2-4, 3-4, ect. evidentally the new CPU just doesn't like one of them. Tried both sticks swapping around and each stick alone in different slots.
So far I am only running 1 of the sticks of ram (2gb), I would prefer to have both in there. This wasn't an issue with the dualcore (2 years no problems) but apparently the quadcore just wants to be **** about the RAM amount.
Any help you can provide would be most excellent.
I am unable to take screenshots of my bios settings otherwise I would do that to help with the troubleshooting.
