Motherboard: Intel DP965LT
CPU: Intel E6700 @ 3.2 GHz
Memory: G-Skill F2-6400CL5D-4GBPQ
Okay so I sent a email to tech support and I got the standard.
"Dear Customer
Please send the memory in for new replacements. http://www.gskill.com/rma.php
The new replacements should work better.
GSKILL SUPPORT"
Before I send it in or get a refund from New egg I need to be certain if it is a compatibility problem or not. I put both sticks in my brother's computer and they run fine. I can run 1 of the sticks in my comp fine (either one, I have tried both). If I run both sticks at the same time in slots 1 &3 or 2 & 4 it takes a long time for the comp to boot. Also if I try to run a game it is painfully slow (with both sticks, fine with only 1 in).
I searched around in the forum for bios settings but there wasn't much help for my ram. If anyone has any ideas I would appreciate it. Thanks.
"Dear Customer
GSKILL SUPPORT"
