Mobo: GA-MA790FX-UD5P with newest BIOS F5
Processor: AMD PhenomII X4 940 Black Edition
RAM: 2 sets of F2-8500CL5D-4GBPK (8gigs total)
OS: Windows XP-64bit
I have successfully installed 4 gigs (2 chips) of this memory at 1033Mhz running stable using the timings listed:
CPU Freq: 200Mhz
Mem clock: X5.33
DDR Voltage: 2.1V
NB Voltage: 1.2V
SPD values:
5-5-5-15
Command timing: 2T
TwTr: 4T
Trfc0: 127ns
Trfc2: 127ns
Write Recovery Time: 8T
Precharge Time: 3T
Row Cycle Time (tRC): 24T
RAS to RAS delay: 4T
However, when I install the 2nd set of memory to total 8 gigs, I get immediate errors in Memtest86+. I can successfully boot into windows and all 8 gigs are recognized by BIOS and Windows, but running Prime 95 gives numerous immediate errors. I've tried all these settings:
DDR Voltage: 2.1V
NB Voltage: 1.4V
SPD values:
5-5-5-15
Command timing: 2T
TwTr: 4T
Trfc0: 127ns (Have tried all of these up to 195ns)
Trfc1: 127ns
Trfc2: 127ns
Trfc3: 127ns
Write Recovery Time: 8T (max i can set to)
Precharge Time: 3T
Row Cycle Time (tRC): 24T (tried up to 42T which is max)
I have ran individual memtests with each stick, and they all pass fine. No matter what I have tried (increasing Trfc to 195ns, increasing tRC up to 42T, increasing NB Voltage to 1.5V) I consistently get many immediate errors when running memtest86+. It runs extremely stable with 4gigs at 1033Mhz, just can't get the full 8 gigs
Plz let me know if there is any more info you need from me and what can be tried to get this working right. Thank you.
CPU Freq: 200Mhz
Mem clock: X5.33
DDR Voltage: 2.1V
NB Voltage: 1.2V
SPD values:
5-5-5-15
Command timing: 2T
TwTr: 4T
Trfc0: 127ns
Trfc2: 127ns
Precharge Time: 3T
DDR Voltage: 2.1V
NB Voltage: 1.4V
SPD values:
5-5-5-15
Command timing: 2T
TwTr: 4T
Trfc1: 127ns
Trfc2: 127ns
Trfc3: 127ns
Precharge Time: 3T
