Hi everybody
I'm new here, and I'am a new GSkill Consummer.
I've a problem with 2 RAM DDR2 "F2-8500CL5D-4GBPI-B" on a motherboard Asus P5Q (CPU Q9550).
Since I installed these new RAM (I had PC6400 before), when Windows is loading, there is a blue screen (with some memory adress
and an errors on the ACPI.SYS).
After, the PC reboot, Windows launch a repair of the system without success ...
My bios is updated to the last version (2208).
I set the RAM timings manually to 5-5-5-15 and their Voltage to 2.1.
I tried to set memory to 1066MHz manually.
I tried with one RAM and the other
I increased the NB voltage to 1.3
Maybe one Ram is wrong but the two at the same time .... It's strange !
Is there an possible incompatibility between the motherboard and these RAM ? Or maybe there are some other values
to change in the bios ?
I don't know ... But it's impossible for me to load windows.
Can you help me ?
Thank you for your help
Can you help me ?
