I'm having trouble getting both sticks to work in my rig. When I put both in the computer will turn on but nothing happens on the screen. I think the one stick is running in single channel but I don't know how to remedy this. I have the one stick set to 1066MHz and its running fine so far. When I put the other stick in there it will look like its on but nothing comes up on the screen. Also I'm running XP Pro 32bit and in system info it says I'm only running 1.7 GB instead of 2. Any insight to these issues would be much appreciated. If someone could just tell me what all the timings for the RAM should be that way I know I'm not screwing anything up. My system specs are:
AMD Phenom 2 x4 955 BE
PC8500- 2x2GB Trident series
Biostar TA790GXE 128M
onboard graphics
onboard graphics
