MB: Asus P5B Del with lateset 1238 BIOS
RAM F2-6400CL4D-4GBPI-B
CPU E6400 currently at stock 8x266
OS Win 7 64
Upgrading RAM from GSkill PC2-6400 GBHZ 2GB kit to the 4GB listed above.
I'm unable to get the system to POST. Fans, HD's all power up but my screen never POST. I've tried all combinations: Blk slots, yellow slots, 1 stick, the other stick in all slots - No POST.
The system has been a rock with the older RAM. System O/C'd at 8x400, RAM at 2.15v (4-4-4-12, withTRFC at 25) for the past 2 years no problems.
Before installing the newer RAM, I lowered killed the OC and set to default 8/226, I lowered the memory voltage to the top of its recommended range 1.9v and set the timings to 4-4-4-12 with TRFC ranging on multiple reboots from 25, 35 & 42 Only options. No Post!
I tried 5-5-5-15 and all the TRFC's to no avail. "Memory Remap" Tried enabled and disabled, Tried "Auto" configure....no go!
I'm beginning to think the RAM may be bad...but the odds on both sticks being bad.....
My brain hurts and my fingers are tired of the RAM swap two step/reboot routine.
I would appreciate any thoughts or guidance,
OS Win 7 64
