I'm having issues with this combination. Every so often the screen will go black, go white, or display artifacts like this on the screen: http://img94.imageshack.us/img94/5638/0102101125.jpg., sometimes with an accompanying buzzing. At first i thought it was a problem with the video card, but after some research this seems to be the culprit. Windows 7 runs normally but seemingly out of the blue it crashes, as described above, and I am forced to hard reboot.
I am using an Intel Core2 Quad Q9400, 2.66, with the cores running at 38, 29, 36 37 Celsius.
Gigabyte GA-EP45-UD3P motherboard the BIOS version FD
2 x 2GB F2-8500CL5D-4GBPK GSkill RAM
The sticks were in 2 and 4 since i put it together, but now I've moved them to 1 and 3. My BIOS is currently set at the following, as per the sticky:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...[AUTO]
CPU Clock Ratio ...........8X
Fine CPU Clock Ratio.......0.0
CPU Frequency .............2.66 GHz (333*8)
Clock Chip Control
>>>Standard Clock Control
CPU Host Clock Control.......[Disabled]
CPU Host Frequency (Mhz) ....333
PCI Express Frequency (Mhz). [AUTO]
C.I.A.2 .....................[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive..................[800mV]
PCI Express Clock Drive..........[900 mV]
CPU Clock Skew (ps)..............0ps
MCH Clock Skew (ps)..............0ps
DRAM Performance Control
Performance Enhance..............[STANDARD]
Extreme Memory Profile (X.M.P.)..[Auto]
(G)MCH Frequency Latch...........[Auto]
System Memory Multiplier ........[3.20B]
Memory Frequency (Mhz) ..........1066
DRAM Timing Selectable ..........[Manual]
Standard Timing Control
CAS Latency Time...5 [5]
tRCD ..............5 [5]
tRP...............5 [5]
tRAS...............15 [15]
Advanced Timing Control
tRRD...............4 [AUTO]
tWTR...............4 [AUTO]
tWR................13 [AUTO]
tRFC...............68 [AUTO]
tRTP...............4 [AUTO]
Command Rate (CMD).0 [2]
Driving Strength Profiles
Driving Strength ......
>>Channel A
Static tRead Value........8
tRD Phase0 Adjustment.....0 [AUTO]
tRD Phase1 Adjustment.....0 [AUTO]
tRD Phase2 Adjustment ....0 [AUTO]
tRD Phase3 Adjustment.....0 [AUTO]
Trd2rd(Different Rank)....8 [AUTO]
Twr2wr(Different Rank)....8 [AUTO]
Twr2rd(Different Rank)....7 [AUTO]
Trd2wr(Same/Diff Rank)....9 [AUTO]
Dimm1 Clock Skew Control....[AUTO]
Dimm2 Clock Skew Control....[AUTO]
DDR Write Training..........[AUTO]
Driving Strength Profile......[AUTO]
Data Driving Pull-up Level....[AUTO]
Cmd Driving Pull-up Level.....[AUTO]
Ctrl Driving Pull-up Level....[AUTO]
Clk Driving Pull-up Level.....[AUTO]
Data Driving Pull-Down Level..[AUTO]
Cmd Driving Pull-Down Level...[AUTO]
Ctrl Driving Pull-Down Level..[AUTO]
Clk Driving Pull-Down Level...[AUTO]
>>Channel B
Static tRead Value..........8 [AUTO]
tRD Phase0 Adjustment.......0 [AUTO]
tRD Phase1 Adjustment.......0 [AUTO]
tRD Phase2 Adjustment ......0 [AUTO]
tRD Phase3 Adjustment.......0 [AUTO]
Trd2rd(Different Rank)......8 [AUTO]
Twr2wr(Different Rank)......8 [AUTO]
Twr2rd(Different Rank)......7 [AUTO]
Trd2wr(Same/Diff Rank)......9 [AUTO]
Dimm1 Clock Skew Control......[AUTO]
Dimm2 Clock Skew Control......[AUTO]
DDR Write Training............[AUTO]
Motherboard Voltage Control
Voltage Type
>>> CPU
Load-Line Calibration [DISABLED]
CPU Vcore...............1.23750v..[AUTO]
CPU Termination?........1.200v....[AUTO]
CPU PLL????.............1.500v....[AUTO]
CPU Reference............:0.760v....[AUTO]
>>>MCH/ICH
MCH Core.........1.100v...[AUTO]
MCH Reference....0.760v...[AUTO]
MCH/DRAM Ref.....0.900v...[AUTO]
ICH I/O..........1.500v...[AUTO]
ICH Core.........1.100v...[AUTO]
>>> DRAM
DRAM Voltage ........1.800v...[2.100v]
DRAM Termination.....0.900v...[AUTO]
Channel A Reference..0.900v...[AUTO]
Channel B Reference..0.900v...[AUTO]
The system still seems to be unstable. Is there a setting I've missed/messed up? I understand that this brand of RAM is not listed on Gigabyte's list of compatible memory. A rep at newegg has told me that i can RMA the GSkill RAM for a refund, allowing me to purchase another brand from Gigabyte's list of tested RAM. Would I be better off trying to troubleshoot this or just trying another brand? (I saw on another post that GSkill and Gigabyte are just plain incompatible, and that there's no real permanent fix.)
Clock Chip Control
>>Channel A
>>Channel B
Voltage Type
>>> CPU
>>>MCH/ICH
>>> DRAM
