Bios settings for using G. Skill F2-6400CL4D-4GBPI-B (8gb’s Pi PC2-6400) with a Gigabyte GA-EP45-UD3P v1.6, and an Intel Quad Core Q6600:
Unless otherwise noted below, the setting is auto
Changes are done in BIOS using the MB Intelligent Tweaker
CPU Host Clock Control (Enabled)
CPU Host Frequency 400mhz FSB (mine is set using 8x CPU multiplier for a 3.2ghz OC)
PCI Express 100
CIA2 (DISABLED)
Advanced Clock Control
CPU Clock 900
PCI Clock 900
CPU Skew 0
MCH Skew 0
Performance Enhance (STANDARD)
System Memory Multiplier SPD 2.00D
Dram Timing (MANUAL)
CAS (CL) 4
tRCD 4
tRP 4
tRAS 12
Advanced Timing Control
tRRD 4
tWTR 4
tWR 8
tRFC 68
tRTP 4
Command Rate CMD 2
Static Read 10
Load Line Calibration (ENABLED)
MCH Core 1.300
ICH Core 1.200
DRAM Voltage 2.00
For Advanced BIOS Settings:
CPU Multi Threading (Enabled)
Limit CPUID (Disabled)
No Execute Memory Protect (Enabled)
CPU Enhanced Halt (Disabled)
CPU Thermal Monitor (Disabled)
Virtualization Technology (Enabled)
Hope this information can help someone else out
PCI Express 100
CIA2 (DISABLED)
CPU Clock 900
PCI Clock 900
CPU Skew 0
MCH Skew 0
CAS (CL) 4
tRCD 4
tRP 4
tRAS 12
tRRD 4
tWTR 4
tWR 8
tRFC 68
tRTP 4
Command Rate CMD 2
Static Read 10
MCH Core 1.300
ICH Core 1.200
DRAM Voltage 2.00
