I just got a 2x2GB F2-6400CL5D-4GBPQ and I had 2x1GB F2-6400CL5-1GBNQ.
I thought these would work together since they have the same timings and are both g.skill.
So I installed the extra 4GB to my Gigabyte 965P-DS4 v1.0 and started installing Windows 7 64-bit.
All went well but after a while the computer started to BSOD so I removed the 2GB-kit and tried again. Still the Windows BSOD so I tried running memtest86 and it got tons of errors immediately. I swapped the RAMS from slot 2/4 to 1/3 but still errors. Also tried the rams by them self, still errors.
So is my RAM faulty or do I need to change any settings? If I get a new pair can I use them with my 2gb g.skill I have since before?
Thanks!
Note that I had no overclock whatsoever when trying this.
Thanks!
