Hi, I have the following:
G.SKILL 4GB (2 x 2GB) DDR2 1066 (PC2 8500) Model F2-8500CL5D-4GBPK
Q6600 G0 SLACR @ 2.4GHz
GIGABYTE EP45-DS3L
SeaSonic M12II SS-500GM
The only way I can get this RAM stable is to run it at the motherboard's AUTO settings with the CPU also at stock settings. Even if I run the CPU at stock and the RAM with manually-configured settings as described on the packaging, Windows will BSOD with some IRQL_LESS_THAN_OR_NOT_EQUAL error.
Do you guys have settings you recommend for running this RAM at various (800MHz/1066MHz) settings on this particular motherboard?
GIGABYTE EP45-DS3L
