Hello, 2 tweeks ago i get this config :
Phenom 2 x4 940 3.0 (deneb) (am2+)
Gigabyte ga-ma78gm-us2h (rev1.0)
G.skill f2-8500cl5d-4gbpi-2 (in dual chanel)
The problem is that the system crash on 1066 (Bsod) , and today on 800 mode reboot on his own.
y pass the memtest86 3.5 and in the first step on 50 % system reboot .
i set the timings like you sayd in Note to AMD AM2+ users...
cpu-z:
DRAM Frequenzy 535.8 Mhz
FSB
RAM 3.8
CAS latency 5.0
ras to cas delay :6
ras precharge : 6
cycle time 24
bank cycle time : 33
command rate: 2t
what yould i do ? i need to increase the nb voltage too ?, or memory problems? , Thanks you .
PD: sorry for my inglish.
cpu-z:
FSB
CAS latency 5.0
ras to cas delay :6
ras precharge : 6
cycle time 24
command rate: 2t
